Home
 Instant  e Books  !
Books
DVD and Video
Buyers Guide
Arc Welding
Braze Cast Iron
Metal Casting
Metal Plating
Arc Equipment
Mig - GMAW
Tig - GTAW
SAW-Sub Arc
Oxy Fuel Welding
Aluminum Weld
Carbon Cutting
Electrodes
Flux Core
Friction Weld
Ironwork
Laser Welding
Metal ID
Metal Art
OxyFuel Cutting
Plasma Cutting
Plasma Welding
Plastic Repair
Resistance Weld
Robotic Welding
Sheet Metal
 Terminology
Thermit Welding
troubleshooting
Underwater Welding
Welding Career
Braze Aluminum
Welding Projects
Weld Symbols
Weld Testing
Electrode Storage
Metal Fume Fever
Safety
110 volt Migs
Welding History
Grinder  Quiz
Safety Quiz
Weld Codes
Powder Coating
Paint a Car
Welding Superbook
rendezvous
110 volt mig welders - Be sure to read entire page !
110 Volt Mig Welders Buyers Guide Gas Metal Arc Welding (GMAW) - MIG
These machines typically come with .023 or .030 dia wire electrode which is typically Flux Cored. However, with the addition of a kit, regulator and wire can be converted over to the short circuit mig with gas option.
110 volt mig welders Gas choices include -
CO2 - least expensive, most penetration, poorest weld appearance but still much better appearance than Flux Cored wire.
75argon/25 CO2 - more expensive, average penetration, good weld appearance, the most widely used mix in the US.
92Argon/8 CO2 - Most expensive, best appearance, least penetration, primarily for sheet metals only (is also used for spray arc mode but that is not attainable with low amperage/voltage output of these machines)
Tri-Mix gas and stainless wire for welding on 16-12 gauge stainless steel.
Argon for welding aluminum
What is 110 volt mig welders Mig/Mag/Short Circuit welding ?
A process used with a wire feed welding machine. Metals are joined by heating them with an arc, which is between the continuously fed filler metal electrode (solid wire) and the workpiece. Externally supplied gas or gas mixture provide shielding.
Easy process to learn Better control on thinner metals Cleaner welds with less slag to clean Equipment can be used for Flux Cored welding Recommended metal: Steel, stainless steel, aluminum, cast iron Skill Level: Low
What is 110 volt mig welders Flux Cored Arc Welding (FCAW) - Gasless
Process that uses a wire-fed welding machine. Metals are melted and joined by heating them with an arc between a continuous, consumable electrode wire and the workpiece. The weld is tubular with flux material contained inside the shielding. Added shielding may or may not be supplied from external gas or gas mixture, depending on the type of flux cored wire being used.
Works well on dirty or rusty material Deep penetration for welding thick sections Can be used with or without shielding gas Self-shielded wire are best for windy conditions Recommended to weld: Steel, stainless steel Skill Level: Low
What to look for when choosing a 110 volt mig welders welder
Typical Applications
Consider the most common uses and applications for your welder: construction, farm/ranch, general maintenance/repair, home, auto body/repair, etc. Welders are designed for certain applications, depending on rated output, duty cycle and other features. For example, heavy-duty repairs in the field requires a welding package that can handle different types and sizes (thickness) of metal, whereas repairing a wrought iron railing can be done using a stick welder.
110 volt mig welders Available Power Input
Single-phase products require single-phase input power usually found in homes and garages (Welders operate off either 115 or 230 Volts) If electrical hook-up is not available, a gas-powered, engine-driven welding generator can supply welding and auxiliary power.
110 volt mig welders Portability
Can the welder be brought to the workpieces, or do the workpieces need to be brought to the welder? Accessories can be used to make most welders portable Hand-portable welders are typically 70 lbs. or less
Glossary of related 110 volt mig welders Terms:
Duty-cycle - The minutes out of a 10-minute period an arc welder can be operated at maximum rated output. For example, a 60% duty cycle @ 300 Amps means that the welding machine can be used for 6 minutes (at 300 Amps) and then must be allowed to cool with the fan running for 4 minutes. This reduces the chance of heat damage to the system.
Electrode - A coated metal wire having the same composition as the material being welded.
Flux - The coating on arc-welding rods and in flux-cored welding wire that is consumed in the arc to produce a shielding gas. The gas displaces air and impurities from around the weld.
Ground Lead/ Workpiece Lead - The conductor cable or electrical conductor between the arc welding machine and the work.
Rated Output - The Amps and voltage the power source will produce for a given duty-cycle period. For example, 300 Amps, 32 load volts @ 60% duty-cycle.
Shielding Gas - Protective gas used to prevent atmospheric contamination of the weld pool. Usually a mixed gas or CO2.
Wire Feed Speed - Expressed as in//min. or mm/s and refers to the speed and amount of filler metal fed into a weld. The higher the wire feed speed, the higher the amperage.
Features to look for in 110 volt mig welders:
Gas solenoid valve
Argon-mix regulator and 5 ft min (1.5 m) gas hose Comfortable 8 ft min (2.4 m) gun with liner for .023-.035 in (0.6-0.9 mm) wire.
Contact tips
Work clamp with 10 ft (3 m) work cable. 1
Spool shaft to accommodate 4 in spools (Optional hub kit available for 8 in spools)
Power cord with plug
Shipping:any charges which might apply
Compare Costs
110 volt mig welders Comparisons
110 volt mig welders, Hobart-125 110 volt mig welders, Hobart-140
footer for 110 volt mig welders page
