Spot Seam and Arc Weld Symbols
The spot weld symbol, in accordance with its location in relation to the reference line, may or may not have arrow side or other side significance.
Dimensions must be shown on the same side of the reference line as the symbol or on either side when the symbol is located astride the reference line and has no arrow side or other side significance.
The process reference is indicated in the tail of the welding symbol. Then projection welding is to be used, the spot weld symbol shall be used with the projection welding process reference in the tail of the welding symbol. The spot weld symbol must be centered above or below the reference line.
Spot Weld Symbol
spot weld symbol
Seam Welding Symbol
seam welding symbol
Size of Arc Seam and Spot Welds
These welds may be dimensioned by either size or strength.
The size of arc spot welds must be designated as the diameter of the weld. Arc seam weld size shall be designated as the width of the weld.
Dimensions will be expressed in fractions or in decimals in hundredths of an inch and shall be shown, with or without inch marks, to the left of the weld symbol (A, fig. 3-38).
The strength of arc spot welds must be designated as the minimum acceptable shear strength in pounds or newtons per spot. In arc seam welds, strength is designated in pounds per linear inch. Strength is shown to the left of the weld symbol (B, fig. 3-38).
Arc Weld Symbols with Dimensions of Arc Spot and Arc Seam Welds
arc weld symbols fig3 38
Spacing of Arc Spot and Arc Seam Welds
The pitch (center-to-center spacing) of arc spot welds and, when indicated, the length of arc seam welds, must be shown to the right of the weld symbol (C, fig. 3-38).
When spot welding or arc seam welding extends for the full distance between abrupt changes in the direction of welding, no length dimension needs to be shown on the welding symbol.
Extent and Number of Arc Spot Welds and Arc Seam Welds
When arc spot welding extends less than the distance between abrupt changes in the direction of welding or less than the full length of the joint, the extent must be dimensioned (fig. 3-39).
Symbol for Extent of Arc Spot Welding
arc spot welding symbol fig3 39
When a definite number of arc spot welds is desired in a certain joint, the number must be shown in parentheses either above or below the related arc weld symbol (fig. 3-40).
Symbol for Number of Arc Spot Welds in a Joint
arc spot welds joint symbol fig3 40
A group of spot welds may be located on a drawing by intersecting center lines. The arrows point to at least one of the center lines passing through each weld location.
Flush Arc Spot and Arc Seam Welded Joints
Flush Arc Spot and Arc Seam Welded Joints. When the exposed surface of one member of an arc spot or arc seam welded joint is to be flush, that surface must be indicated by adding the flush contour symbol (fig. 3-41) in the same manner as that for fillet welds.
Symbol for Surface Contour of Arc Spot and Arc Seam Welds
surface contour arc weld symbol fig3 41
Details of Arc Seam Welds
The spacing, extent, orientation, and location of arc seam welds cannot be shown on the welding symbols. This data must be shown on the drawing.
