Home
Arc Welding
Braze Cast Iron
Metal Casting
Metal Plating
Arc Equipment
Mig - GMAW
Tig - GTAW
SAW-Sub Arc
Oxy Fuel Welding
Aluminum Weld
Carbon Cutting
Electrodes
Flux Core
Friction Weld
Ironwork
Laser Welding
Metal ID
Metal Art
OxyFuel Cutting
Plasma Cutting
Plasma Welding
Plastic Repair
Resistance Weld
Robotic Welding
Sheet Metal
 Terminology
Thermit Welding
troubleshooting
Underwater Welding
Welding Career
Braze Aluminum
Welding Projects
Weld Symbols
Weld Testing
Electrode Storage
Metal Fume Fever
Safety
110 volt Migs
Welding History
Grinder  Quiz
Safety Quiz
Weld Codes
Powder Coating
Paint a Car
DVD and Video
Buyers Guide
rendezvous
Water Injection Plasma
(c) Water injection plasma cutting.
This modification of the PAC process uses a symmetrical impinging water jet near the constricting nozzle orifice to further constrict the plasma flame.
The arrangement is shown in figure 10-74.
The water jet also shields the plasma from mixing with the surrounding atmosphere.
The end of the nozzle can be made of ceramic, which helps to prevent double arcing.
The water constricted plasma produces a narrow, sharply defined cut at speeds above those of conventional PAC.
Because most of the water leaves the nozzle as a liquid spray, it cools the kerf edge, producing a sharp corner.
The kerf is clean.
When the orifice gas and water are injected in tangent, the plasma gas swirls as it emerges from the nozzle and water jet.
This can produce a high quality perpendicular face on one side of the kerf.
The other side of the kerf is beveled.
In shape cutting applications, the direction of travel must be selected to produce a perpendicular cut on the part and the bevel cut on the scrap.
