Welding Career, Welding Job, Welder
Occupational Outlook Handbook
More than 6 out of 10 jobs are found in manufacturing industries.
Training ranges from a few weeks of school or on-the-job training for low-skilled positions to several years of combined school and on-the-job training for highly skilled jobs.
Employment is projected to grow more slowly than average.
Job prospects should be excellent as employers report difficulty finding enough qualified people.
Welding Career, Welding Job, Welder Nature of the Work
Welding is the most common way of permanently joining metal parts. In this process, heat is applied to metal pieces, melting and fusing them to form a permanent bond. Because of its strength, welding is used in shipbuilding, automobile manufacturing and repair, aerospace applications, and thousands of other manufacturing activities. Welding also is used to join beams when constructing buildings, bridges, and other structures, and to join pipes in pipelines, power plants, and refineries.
Welders use many types of welding equipment set up in a variety of positions, such as flat, vertical, horizontal, and overhead. They may perform manual welding, in which the work is entirely controlled by the welder, or semiautomatic welding, in which the welder uses machinery, such as a wire feeder, to perform welding tasks.
There are about 100 different types of welding. Arc welding is the most common type. Standard arc welding involves two large metal alligator clips that carry a strong electrical current. One clip is attached to any part of the workpiece being welded. The second clip is connected to a thin welding rod. When the rod touches the workpiece, a powerful electrical circuit is created. The massive heat created by the electrical current causes both the workpiece and the steel core of the rod to melt together, cooling quickly to form a solid bond. During welding, the flux that surrounds the rod’s core vaporizes, forming an inert gas that serves to protect the weld from atmospheric elements that might weaken it. Welding speed is important. Variations in speed can change the amount of flux applied, weakening the weld, or weakening the surrounding metal by increasing heat exposure.
Two common but advanced types of arc welding are Tungsten Inert Gas (TIG) and Metal Inert Gas (MIG) welding. TIG welding often is used with stainless steel or aluminum. While TIG uses welding rods, MIG uses a spool of continuously fed wire, which allows the welder to join longer stretches of metal without stopping to replace the rod. In TIG welding, the welder holds the welding rod in one hand and an electric torch in the other hand. The torch is used to simultaneously melt the rod and the workpiece. In MIG welding, the welder holds the wire feeder, which functions like the alligator clip in arc welding. Instead of using gas flux surrounding the rod, TIG and MIG protect the initial weld from the environment by blowing inert gas onto the weld.
Like arc welding, soldering and brazing use molten metal to join two pieces of metal. However, the metal added during the process has a melting point lower than that of the workpiece, so only the added metal is melted, not the workpiece. Soldering uses metals with a melting point below 800 degrees Fahrenheit; brazing uses metals with a higher melting point. Because soldering and brazing do not melt the workpiece, these processes normally do not create the distortions or weaknesses in the workpiece that can occur with welding. Soldering commonly is used to join electrical, electronic, and other small metal parts. Brazing produces a stronger joint than does soldering, and often is used to join metals other than steel, such as brass. Brazing can also be used to apply coatings to parts to reduce wear and protect against corrosion.
Skilled welding, soldering, and brazing workers generally plan work from drawings or specifications or use their knowledge of fluxes and base metals to analyze the parts to be joined. These workers then select and set up welding equipment, execute the planned welds, and examine welds to ensure that they meet standards or specifications. They are even examining the weld while they’re welding. By observing problems with the weld, they compensate by adjusting the speed, voltage, amperage, or feed of the rod. Highly skilled welders often are trained to work with a wide variety of materials in addition to steel, such as titanium, aluminum, or plastics. Some welders have more limited duties, however. They perform routine jobs that already have been planned and laid out and do not require extensive knowledge of welding techniques.
Automated welding is used in an increasing number of production processes. In these instances, a machine or robot performs the welding tasks while monitored by a welding machine operator. Welding, soldering, and brazing machine setters, operators, and tenders follow specified layouts, work orders, or blueprints. Operators must load parts correctly and constantly monitor the machine to ensure that it produces the desired bond.
The work of arc, plasma, and oxy-gas cutters is closely related to that of welders. However, instead of joining metals, cutters use the heat from an electric arc, a stream of ionized gas (plasma), or burning gases to cut and trim metal objects to specific dimensions. Cutters also dismantle large objects, such as ships, railroad cars, automobiles, buildings, or aircraft. Some operate and monitor cutting machines similar to those used by welding machine operators. Plasma cutting has been increasing in popularity because, unlike other methods, it can cut a wide variety of metals, including stainless steel, aluminum, and titanium.
Welding Career, Welding Job, Welder Working Conditions
Welding, soldering, and brazing workers often are exposed to a number of hazards, including the intense light created by the arc, poisonous fumes, and very hot materials. They wear safety shoes, goggles, hoods with protective lenses, and other devices designed to prevent burns and eye injuries and to protect them from falling objects. They normally work in well-ventilated areas to limit their exposure to fumes. Automated welding, soldering, and brazing machine operators are not exposed to as many dangers, however, and a face shield or goggles usually provide adequate protection for these workers.
Welders and cutters may work outdoors, often in inclement weather, or indoors, sometimes in a confined area designed to contain sparks and glare. Outdoors, they may work on a scaffold or platform high off the ground. In addition, they may be required to lift heavy objects and work in a variety of awkward positions, while bending, stooping, or standing to perform work overhead.
Although about 52 percent of welders, solderers, and brazers work a 40-hour week, overtime is common, and some welders work up to 70 hours per week. Welders also may work in shifts as long as 12 hours. Some welders, solderers, brazers, and machine operators work in factories that operate around the clock, necessitating shift work.
Welding Career, Welding Job, Welder Training, Other Qualifications, and Advancement
Training for welding, soldering, and brazing workers can range from a few weeks of school or on-the-job training for low-skilled positions to several years of combined school and on-the-job training for highly skilled jobs. Formal training is available in high schools, vocational schools, and postsecondary institutions, such as vocational-technical institutes, community colleges, and private welding schools. The Armed Forces operate welding schools as well. While some employers provide basic training, they prefer to hire workers with experience or more formal training. Courses in blueprint reading, shop mathematics, mechanical drawing, physics, chemistry, and metallurgy are helpful. An understanding of electricity also is very helpful and knowledge of computers is gaining importance, especially for welding, soldering, and brazing machine operators, who are becoming more responsible for the programming of computer-controlled machines, including robots.
Some welders become certified, a process whereby the employer sends a worker to an institution, such as an independent testing lab, equipment manufacturer, or technical school, to weld a test specimen according to specific codes and standards required by the employer. Testing procedures are based on the standards and codes set by industry associations with which the employer may be affiliated. If the welding inspector at the examining institution determines that the worker has performed according to the employer’s guidelines, the inspector will then certify that the welder being tested is able to work with a particular welding procedure.
Welding, soldering, and brazing workers need good eyesight, hand-eye coordination, and manual dexterity. They should be able to concentrate on detailed work for long periods and be able to bend, stoop, and work in awkward positions. In addition, welders increasingly need to be willing to receive training and perform tasks in other production jobs.
Welders can advance to more skilled welding jobs with additional training and experience. For example, they may become welding technicians, supervisors, inspectors, or instructors. Some experienced welders open their own repair shops.
Welding Career, Welding Job, Welder Employment
Welding, soldering, and brazing workers held about 429,000 jobs in 2004. Of these jobs, more than 6 of every 10 were found in manufacturing. Jobs were concentrated in fabricated metal product manufacturing, transportation equipment manufacturing (motor vehicle body and parts and ship and boat building), machinery manufacturing (agriculture, construction, and mining machinery), architectural and structural metals manufacturing, and construction. Most jobs for welding, soldering, and brazing machine setters, operators, and tenders were found in the same manufacturing industries as skilled welding, soldering, and brazing workers.
Welding Career, Welding Job, Welder Job Outlook
Employment of welding, soldering, and brazing workers is expected to grow more slowly than average for all occupations over the 2004-14 period. Despite this, job prospects should be excellent as employers report difficulty finding enough qualified people. In addition, many openings are expected to arise as a large number of workers retire over the next decade.
The major factor affecting employment of welders is the health of the industries in which they work. The manufacturing sector, which employs the most welding, soldering, and brazing workers, is expected to continue to decline as more manufacturing moves overseas. Because almost every manufacturing industry uses welding at some stage of manufacturing or in the repair and maintenance of equipment, this overall decline will affect the demand for welders, although some industries will fare better than others. The construction industry is expected to have solid growth over the next decade and an increasing demand for welders. Government funding for shipbuilding as well as for infrastructure repairs and improvements are expected to generate additional welding jobs.
Pressures to improve productivity and hold down labor costs are leading many companies to invest more in automation, especially computer-controlled and robotically controlled welding machinery. This will reduce the demand for some welders, solderers, and brazers because many repetitive jobs are being automated. The growing use of automation, however, should increase demand for welding, soldering, and brazing machine setters, operators, and tenders. Welders working on construction projects or in equipment repair will not be affected by technology change to the same extent, because their jobs are often unique and not as easily automated.
Despite slower-than-average job growth, technology is creating more uses for welding in the workplace and expanding employment opportunities. For example, new ways are being developed to bond dissimilar materials and nonmetallic materials, such as plastics, composites, and new alloys. Also, laser beam and electron beam welding, new fluxes, and other new technologies and techniques are improving the results of welding, making it useful in a wider assortment of applications. Improvements in technology have also boosted welding productivity, making welding more competitive with other methods of joining materials.
Welding Career, Welding Job, Welder Earnings
Median hourly earnings of welders, cutters, solderers, and brazers were $14.72 in May 2004. The middle 50 percent earned between $11.90 and $18.05. The lowest 10 percent had earnings of less than $9.79, while the top 10 percent earned over $22.20. The range of earnings of welders reflects the wide range of skill levels. Median hourly earnings in the industries employing the largest numbers of welders, cutters, solderers, and brazers in May 2004 were:
Motor vehicle parts manufacturing $16.47
Agriculture, construction, and mining machinery manufacturing 14.12
Architectural and structural metals manufacturing 13.98
Commercial and industrial machinery and equipment (except automotive and electronic) repair and maintenance 13.45
Motor vehicle body and trailer manufacturing 13.45
Median hourly earnings of welding, soldering, and brazing machine setters, operators, and tenders were $14.32 in May 2004. The middle 50 percent earned between $11.73 and $17.78. The lowest 10 percent had earnings of less than $9.63, while the top 10 percent earned over $23.54. Median hourly earnings in motor vehicle parts manufacturing, the industry employing the largest numbers of welding machine operators in May 2004, were $15.43.
Many welders belong to unions. Among these are the International Association of Machinists and Aerospace Workers; the International Brotherhood of Boilermakers, Iron Ship Builders, Blacksmiths, Forgers and Helpers; the International Union, United Automobile, Aerospace and Agricultural Implement Workers of America; the United Association of Journeymen and Apprentices of the Plumbing, Pipefitting, Sprinkler Fitting Industry of the United States and Canada; and the United Electrical, Radio, and Machine Workers of America.
Welding Career, Welding Job, Welder Related Occupations
Welding, soldering, and brazing workers are skilled metal workers. Other metal workers include Machinists; machine setters, operators, and tenders—metal and plastic; computer control programmers and operators; tool and die makers; sheet metal workers; and boilermakers. Assemblers and fabricators of electrical and electronic equipment often assemble parts using soldering.
For information on training opportunities and jobs for welding, soldering, and brazing workers, contact local employers, the local office of the State employment service, or schools providing welding, soldering, or brazing training.
Information on careers and educational opportunities in welding is available from:
American Welding Society, 550 N.W. Lejeune Rd., Miami, FL 33126. Internet: http://www.aws.org
